Ir para o conteúdo principal
Installing a Professor Patch on a Patagonia Sweater
O que você precisa
  1. Installing a Professor Patch on a Patagonia Sweater, Professor Patch: passo 1, imagem 1 %32 Installing a Professor Patch on a Patagonia Sweater, Professor Patch: passo 1, imagem 2 %32 Installing a Professor Patch on a Patagonia Sweater, Professor Patch: passo 1, imagem 3 %32
    • Lay your sweater flat on a work surface, damage side up.
    • Measure the length of the hole.
    • Measure the width of the hole.
  2. Installing a Professor Patch on a Patagonia Sweater: passo 2, imagem 1 %32 Installing a Professor Patch on a Patagonia Sweater: passo 2, imagem 2 %32 Installing a Professor Patch on a Patagonia Sweater: passo 2, imagem 3 %32
    • On a piece of paper, mark the endpoints of a line that measures the length of the hole, plus one inch.
    • Mark the center of the two endpoints.
    • From the center, turn the measuring tape 90 degrees. Mark the endpoints of a line that measures the width of the hole, plus one inch.
  3. Installing a Professor Patch on a Patagonia Sweater: passo 3, imagem 1 %32 Installing a Professor Patch on a Patagonia Sweater: passo 3, imagem 2 %32 Installing a Professor Patch on a Patagonia Sweater: passo 3, imagem 3 %32
    • Sketch a curve connecting the endpoints of the length and width.
    • Draw a straight line connecting the endpoints of the width, going though the center point.
    • Fold the paper in half on the straight line.
    • Cut along the curved line. The piece you have just cut out will be your pattern.
  4. Installing a Professor Patch on a Patagonia Sweater: passo 4, imagem 1 %32 Installing a Professor Patch on a Patagonia Sweater: passo 4, imagem 2 %32
    • Lay your pattern over the hole to verify that it is the correct size and shape.
  5. Installing a Professor Patch on a Patagonia Sweater: passo 5, imagem 1 %32 Installing a Professor Patch on a Patagonia Sweater: passo 5, imagem 2 %32 Installing a Professor Patch on a Patagonia Sweater: passo 5, imagem 3 %32
    • Lay your pattern over the piece of fabric you’ve choosen to use as a patch.
    • It is important to choose a fabric that is only slightly heavier than your sweater, such as corduroy or a felted sweater. Anything heavier, such as denim or leather, may cause the sweater to tear.
    • To felt a sweater, simply put a 100% wool sweater through the washer and dryer. When it comes out, the sweater should be shrunken and have a very tight weave.
    • Pin your pattern piece onto your patch fabric.
    • If you double up the patch fabric before you pin you will get two identical patches, one for each side.
  6. Installing a Professor Patch on a Patagonia Sweater: passo 6, imagem 1 %32 Installing a Professor Patch on a Patagonia Sweater: passo 6, imagem 2 %32
    • Using fabric scissors, cut around the pattern piece.
    • Inspect the patch, going back to clean up any rough edges with scissors.
  7. Installing a Professor Patch on a Patagonia Sweater: passo 7, imagem 1 %32 Installing a Professor Patch on a Patagonia Sweater: passo 7, imagem 2 %32
    • Lay the patch over the hole, positioning it where you would like it to be.
  8. Installing a Professor Patch on a Patagonia Sweater: passo 8, imagem 1 %32 Installing a Professor Patch on a Patagonia Sweater: passo 8, imagem 2 %32
    • Pin the patch into place.
    • Only pin the patch to the top layer of the sleeve fabric; if you pin and sew them both, you will sew the sleeve shut.
  9. Installing a Professor Patch on a Patagonia Sweater: passo 9, imagem 1 %32 Installing a Professor Patch on a Patagonia Sweater: passo 9, imagem 2 %32 Installing a Professor Patch on a Patagonia Sweater: passo 9, imagem 3 %32
    • Insert a ballpoint needle into your sewing machine.
    • Each sewing machine is a little bit different, so check your user's manual if you aren't sure how to change your needle.
  10. Installing a Professor Patch on a Patagonia Sweater: passo 10, imagem 1 %32 Installing a Professor Patch on a Patagonia Sweater: passo 10, imagem 2 %32 Installing a Professor Patch on a Patagonia Sweater: passo 10, imagem 3 %32
    • Slide the sleeve over the arm of your sewing machine, just like you’d put the sleeve over your own arm.
    • You may need to remove the table from your sewing machine to allow the sweater sleeve to slide over the sewing machine arm. Check you sewing machine manual for specific instructions on your machine.
  11. Installing a Professor Patch on a Patagonia Sweater: passo 11, imagem 1 %32 Installing a Professor Patch on a Patagonia Sweater: passo 11, imagem 2 %32 Installing a Professor Patch on a Patagonia Sweater: passo 11, imagem 3 %32
    • Align the very edge of the patch with the needle.
    • Sew around the edge of the patch, turning the sleeve as you go.
    • For a more stable patch, use zig-zag or satin stitch.
    • Sew until you come all the way around, retracing your first stitches.
  12. Installing a Professor Patch on a Patagonia Sweater: passo 12, imagem 1 %32 Installing a Professor Patch on a Patagonia Sweater: passo 12, imagem 2 %32 Installing a Professor Patch on a Patagonia Sweater: passo 12, imagem 3 %32
    • Slide the sleeve off the arm of your sewing machine.
    • Clip any loose threads.
    • Repeat on the other sleeve if you want symmetrical professor patches.
Conclusão
If you need further help, contact Patagonia Customer Service.
3 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
89.014 Reputação
Autoria de 131 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 14
Últimos 7 dias: 151
Últimos 30 dias: 721
Duração total: 82,441
