Ir para o conteúdo principal
Installing a Petsafe Removable Dog Panel
O que você precisa
  1. Installing a Petsafe Removable Dog Panel, Petsafe Dog Panel: passo 1, imagem 1 %32
    • Make sure you have all the tools necessary.
  2. Installing a Petsafe Removable Dog Panel: passo 2, imagem 1 %32
    • Receive your PetSafe dog door in the mail.
  3. Installing a Petsafe Removable Dog Panel: passo 3, imagem 1 %32 Installing a Petsafe Removable Dog Panel: passo 3, imagem 2 %32
    • Measure the height of the sliding glass door frame.
  4. Installing a Petsafe Removable Dog Panel: passo 4, imagem 1 %32 Installing a Petsafe Removable Dog Panel: passo 4, imagem 2 %32 Installing a Petsafe Removable Dog Panel: passo 4, imagem 3 %32
    • Remove your lock latch from the sliding door frame.
    • Lock latches may vary
  5. Installing a Petsafe Removable Dog Panel: passo 5, imagem 1 %32 Installing a Petsafe Removable Dog Panel: passo 5, imagem 2 %32
    • Slide the top of your dog panel into the top track of the sliding glass door.
    • Place the bottom portion of the dog panel into the bottom track of the sliding glass door.
  6. Installing a Petsafe Removable Dog Panel: passo 6, imagem 1 %32 Installing a Petsafe Removable Dog Panel: passo 6, imagem 2 %32
    • Measure 12” from the top, down the side of your sliding glass door frame and mark it.
    • Mark 1” above the pet flap onto the edge of your sliding glass door.
  7. Installing a Petsafe Removable Dog Panel: passo 7, imagem 1 %32 Installing a Petsafe Removable Dog Panel: passo 7, imagem 2 %32 Installing a Petsafe Removable Dog Panel: passo 7, imagem 3 %32
    • With a 9/64ths drill bit, drill clearance holes into the marks made on the sliding glass door frame
    • DO NOT GO THROUGH THE DOG PANEL
  8. Installing a Petsafe Removable Dog Panel: passo 8, imagem 1 %32 Installing a Petsafe Removable Dog Panel: passo 8, imagem 2 %32 Installing a Petsafe Removable Dog Panel: passo 8, imagem 3 %32
    • Fasten the panel to the interior side of the sliding glass frame with the provided ⅝” screws.
    • MAKE SURE YOU ARE DRILLING OUTSIDE OF THE RIBBED LINE ON THE DOG PANEL.
    • DO NOT OVERTIGHTEN.
  9. Installing a Petsafe Removable Dog Panel: passo 9, imagem 1 %32 Installing a Petsafe Removable Dog Panel: passo 9, imagem 2 %32
    • Tighten the screws with a screwdriver.
  10. Installing a Petsafe Removable Dog Panel: passo 10, imagem 1 %32 Installing a Petsafe Removable Dog Panel: passo 10, imagem 2 %32 Installing a Petsafe Removable Dog Panel: passo 10, imagem 3 %32
    • Repeat steps 8 and 9 to secure the dog panel into place. Follow these steps when drilling into the clearance hole marked at the top of the frame.
  11. Installing a Petsafe Removable Dog Panel: passo 11, imagem 1 %32
    • Slide your sliding door flush against the dog door.
Conclusão
Uma outra pessoa concluiu este guia.
Joshua Novello
Membro desde: 10/26/18
196 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S1-G1, Bender Fall 2018 Membro de UC Davis, Team S1-G1, Bender Fall 2018
UCD-BENDER-F18S1G1
Membros da 3
1 Guia de autoria
2 comentários
My dog won’t push hard enough for the magnet to open. Is there a way to temporarily remove the magnet on either the frame or the flap?
LisaD - Responder
LisaD put a piece of masking tape over the magnet or a couple of layers of tape to make it easier to open maybe?
Robert Merry -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 51
Duração total: 1,146
