Introdução
If your Ford F250 (or any other truck) does not come with LED roof cab lights, you can get some aftermarket LED cab lights to give it that gritty, off-road look.
O que você precisa
Lower the headliner. You'll need to remove both visors and the overhead storage console.
Get your fingers where you can grab the (4) metal clips to release.
You will also need to remove the driver and passenger side A-pillar covers.
Draw a line perpendicular to the sides of the truck and measure the distance from the windshield molding by the driver's side door. You will basically need to draw a horizontal straight line from both sides of the truck and then find the center of the truck. Use the midpoint as a guideline and measure where you will be placing the rest.
Test to see if your LED truck roof lights work and enjoy!
Uma outra pessoa concluiu este guia.
