Introdução
There are many benefits to adding a second hard drive to your laptop such as improved speeds, greater storage space, and less heartache when installing new software. Use this guide to install one using our optical bay hard drive enclosure.
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Grab the translucent plastic tab and pull the battery up and out of the Unibody.
If the latch is depressed it will lock the battery in place.
Remove the following eight screws securing the lower case to the chassis:
One 5.4 mm Phillips screw.
Three 14 mm Phillips screws.
Four 3.5 mm Phillips screws.
Disconnect the camera cable by pulling the male end straight away from its socket.
Remove the optical drive cable by pulling it straight away from the optical drive.
Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
Remove the plastic spacer from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
Make sure that the hard drive connectors are facing down before placing it into the enclosure.
Gently place the hard drive into the enclosure's hard drive slot.
While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
85 outras pessoas concluíram este guia.
5 comentários
Thank you for this very comprehensive guide. I have been able to use it to add a 2nd 1TB Hard Drive to my smaller 13-inch, Aluminum, Late 2008 Macbook in lieu of its original SuperDrive. However, I am unable to see this 2nd drive on my desktop. This is despite the fact that I have checked “Hard disks” under the General tab in Preferences. I only see my 1st 500 Gb SSD boot drive. What can I do to have the 2nd Hard Drive show on my desktop as well?
Ok, I formatted the new HD and it can now be seen on my desktop!
Hi, I’m planning to do the 2nd disk op, however my idea is to add either a 2Tb SSD or 4TB SSD, leaving the OS and the std office tools (write, table, presentation) on original HDD. SSD would contain data and video/photo editing tools.
Does anyone know if the late2008 accepts, runs the above 1Tb drives (SSDs or HDDs)?
I’ve heard so many no/yes/hmmm/ney replies, seems that no one knows. Not even Apple Support team.
I would be grateful if somebody is able to give a solid advice on this matter.
One of the CDRom small screw got damage and it wont be unscrew is there away for me to remove the CD Rom? Help?
Richard Tirtadji: you can try to fix a “good” screw with a strong glue on the top of the defective one. There are how-to’s at youtube.
