Ir para o conteúdo principal
Install macOS Printer Drivers
  1. Install macOS Printer Drivers, Install macOS Printer Drivers: passo 1, imagem 1 %32 Install macOS Printer Drivers, Install macOS Printer Drivers: passo 1, imagem 2 %32
    • Find the driver for your printer brand on the link below:
    • https://support.apple.com/kb/index?page=...
    • Download the driver for your printer, by clicking on the "Download" button.
    • If the message: "This connection is not private" appears, open the page with the private mode of your browser.
    Pergunte ao FixBot
    Comentar
  2. Install macOS Printer Drivers: passo 2, imagem 1 %32 Install macOS Printer Drivers: passo 2, imagem 2 %32
    • Open your .dmg file
    • Open your .pkg file
    • If this message appears: "This update requires macOS 12.0 or earlier." click Close and continue with the next step.
    • Otherwise, continue with step 7.
    Pergunte ao FixBot
    Comentar
  3. Install macOS Printer Drivers: passo 3, imagem 1 %32 Install macOS Printer Drivers: passo 3, imagem 2 %32 Install macOS Printer Drivers: passo 3, imagem 3 %32
    • Move your .pkg file to your desktop
    • Open Terminal
    • Enter: cd Desktop/ then press the Enter key
    Pergunte ao FixBot
    Comentar
  4. Install macOS Printer Drivers: passo 4, imagem 1 %32 Install macOS Printer Drivers: passo 4, imagem 2 %32 Install macOS Printer Drivers: passo 4, imagem 3 %32
    • Enter the following command: pkgutil --expand FileName.pkg FileName
    • Change FileName to the name of your file, in both places.
    • Then press the Enter key.
    • A folder with the file name appears on your desktop.
    • Open the folder.
    Pergunte ao FixBot
    Comentar
  5. Install macOS Printer Drivers: passo 5, imagem 1 %32 Install macOS Printer Drivers: passo 5, imagem 2 %32
    • Open the Distribution file with TextEdit
    • Then change the number after (system.compareVersions(system.version.ProductVersion, '12.0')" to that of your macOS version or later.
    • Save the file and close it.
    Pergunte ao FixBot
    Comentar
  6. Install macOS Printer Drivers: passo 6, imagem 1 %32 Install macOS Printer Drivers: passo 6, imagem 2 %32
    • Return to the Terminal
    • Enter the following command: pkgutil --flatten FileName FileName.pkg and press the Enter key.
    • Close theTerminal and open FileName.pkg on your desktop.
    Pergunte ao FixBot
    Comentar
  7. Install macOS Printer Drivers: passo 7, imagem 1 %32
    • Congratulations, you can proceed with the installation by following the steps one by one.
    Pergunte ao FixBot
    Comentar
Conclusão
Congratulations, you made it!
3 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
fr en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Anthony Fassler
Membro desde: 02/26/15
6.991 Reputação
Autoria de 4 guias
2Comentários do guia
Merci pour cet excellent tutoriel, j'ai récupéré le fonctionnement de mon ancienne imprimante HP sur mon Mac !
Bravo !!!
Cédric Trocellier - Responder Compartilhar
Bonjours ,j'ai un ordinateur imac et je veux installer une imprimante canon, je dois telecharger un logiciel pour ça et je n'y arrive pas; pouvez vous m'aider svp; merci
Moh Cho - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 30
Últimos 30 dias: 126
Ao todo: 5,347
