Ir para o conteúdo principal
Install Audi A5 LED License Plate Lights
O que você precisa
  1. Install Audi A5 LED License Plate Lights, license plate lights: passo 1, imagem 1 %32 Install Audi A5 LED License Plate Lights, license plate lights: passo 1, imagem 2 %32 Install Audi A5 LED License Plate Lights, license plate lights: passo 1, imagem 3 %32
    • Get a Philips screwdriver and remove the screws from the license plate lamps.
  2. Install Audi A5 LED License Plate Lights: passo 2, imagem 1 %32 Install Audi A5 LED License Plate Lights: passo 2, imagem 2 %32
    • Remove the stock license plate bulb.
  3. Install Audi A5 LED License Plate Lights: passo 3, imagem 1 %32
    • Directly replace it with the new Error Free LED bulb.
    • Remember to have the LED emitter facing outwards, towards the license plate lens.
  4. Install Audi A5 LED License Plate Lights: passo 4, imagem 1 %32 Install Audi A5 LED License Plate Lights: passo 4, imagem 2 %32 Install Audi A5 LED License Plate Lights: passo 4, imagem 3 %32
    • Put the license plate lamp back and screw in the assembly.
    • Repeat on the other side.
Conclusão
Installing this LED license plate bulb is extremely easy and straightforward. Make sure to test everything to see if it works.
5 outras pessoas executaram este guia.
Eric Wu
Membro desde: 01/21/15
3.357 Reputação
Autoria de 23 guias
Um comentário
Please consider that LED replacement bulbs like the linked one usually are not labelled with the mark of conformity and therefore not legal within the EU. For some cars legal LED replacements are available as original spare parts from the car manufacturer.
Sacacorchos de Otraluz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 35
Duração total: 9,149
