Ir para o conteúdo principal
Inspiron 7359 2-in-1 WiFi Card Replacement
O que você precisa
  1. Inspiron 7359 2-in-1 WiFi Card Replacement, Bottom Case: passo 1, imagem 1 %32
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 WiFi Card Replacement: passo 2, imagem 1 %32 Inspiron 7359 2-in-1 WiFi Card Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 WiFi Card Replacement: passo 3, imagem 1 %32
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 WiFi Card Replacement: passo 4, imagem 1 %32
    • All hardware components should be exposed.
  5. Inspiron 7359 2-in-1 WiFi Card Replacement, WiFi Card: passo 5, imagem 1 %32 Inspiron 7359 2-in-1 WiFi Card Replacement, WiFi Card: passo 5, imagem 2 %32
    • Use the spudger tool to remove the two antenna cables.
    • Remove the black screw.
    • Slightly pull up the end and remove the WiFi card. Be careful not to damage the internal adapter.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Gateway, Team S1-G3, Saknee Fall 2019 Membro de Gateway, Team S1-G3, Saknee Fall 2019
GCC-SAKNEE-F19S1G3
4 Membros
Autoria de 6 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 42
Ao todo: 216
