Ir para o conteúdo principal
Inspiron 7359 2-in-1 Fan Replacement
O que você precisa
  1. Inspiron 7359 2-in-1 Fan Replacement, Disassembling the Inspiron 7359 2-in-1: passo 1, imagem 1 %32
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Fan Replacement: passo 2, imagem 1 %32 Inspiron 7359 2-in-1 Fan Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Fan Replacement: passo 3, imagem 1 %32
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Fan Replacement: passo 4, imagem 1 %32
    • All hardware components should be exposed.
  5. Cuidado: as etapas de 5 a 6 são provenientes de um guia marcado como em andamento.
    Inspiron 7359 2-in-1 Fan Replacement, Hard Disk Drive: passo 5, imagem 1 %32
    • Unscrew three 3mm screws with a Phillips #0 screwdriver and remove them.
    • These screws hold the hdd and removing these screws will make it easier to remove it.
  6. Inspiron 7359 2-in-1 Fan Replacement: passo 6, imagem 1 %32 Inspiron 7359 2-in-1 Fan Replacement: passo 6, imagem 2 %32
    • Lift the hard drive from the left side. Be careful not pull on it.
    • Pull the SATA cable that's connect to the hard drive and then carefully place the cable on the side.
  7. Inspiron 7359 2-in-1 Fan Replacement, Fan: passo 7, imagem 1 %32 Inspiron 7359 2-in-1 Fan Replacement, Fan: passo 7, imagem 2 %32
    • Carefully pull the fan adapter labelled one.
  8. Inspiron 7359 2-in-1 Fan Replacement: passo 8, imagem 1 %32
    • Pull the wire from the hook to make it easier to take the whole fan out.
  9. Inspiron 7359 2-in-1 Fan Replacement: passo 9, imagem 1 %32
    • Remove one 5mm screw using the Phillips screw.
    • After the screw is extracted use your hands and carefully take the fan out.
Conclusão
Dominique
Membro desde: 08/26/19
251 Reputação
Autoria de 2 guias
Equipe
Gateway, Team S1-G3, Saknee Fall 2019 Membro de Gateway, Team S1-G3, Saknee Fall 2019
GCC-SAKNEE-F19S1G3
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 418
