Ir para o conteúdo principal
Inspiron 7359 2-in-1 Battery Replacement
O que você precisa
  1. Inspiron 7359 2-in-1 Battery Replacement, Bottom Case: passo 1, imagem 1 %32
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Battery Replacement: passo 2, imagem 1 %32 Inspiron 7359 2-in-1 Battery Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Battery Replacement: passo 3, imagem 1 %32
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Battery Replacement: passo 4, imagem 1 %32
    • All hardware components should be exposed.
  5. Inspiron 7359 2-in-1 Battery Replacement, Battery: passo 5, imagem 1 %32
    • Unscrew two 8mm screws with a Phillips #0 screwdriver.
    • Unscrew one silver, wide-head, 8mm screw with a Phillips #0 screwdriver.
    • Disconnect the battery cable from the motherboard.
    • Make sure to keep all screws together and label where you unscrewed them from.
  6. Inspiron 7359 2-in-1 Battery Replacement: passo 6, imagem 1 %32
    • To remove the old battery, lift from the bottom and pull the battery towards you.
Conclusão
To reassemble your device, follow these instructions in reverse order using a new battery.
Alfredo Acosta
Membro desde: 08/26/19
141 Reputação
Autoria de 1 guia
Equipe
Gateway, Team S1-G3, Saknee Fall 2019 Membro de Gateway, Team S1-G3, Saknee Fall 2019
GCC-SAKNEE-F19S1G3
4 Membros
Autoria de 6 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 56
Ao todo: 189
