Introdução
Once you have the back dissembled, feel free to follow this guide to see how you can replace the battery.
O que você precisa
Turn the laptop upside down with the logo facing the surface of the table.
Unscrew two 8mm screws with a Phillips #0 screwdriver.
Unscrew one silver, wide-head, 8mm screw with a Phillips #0 screwdriver.
Disconnect the battery cable from the motherboard.
To reassemble your device, follow these instructions in reverse order using a new battery.
