Ir para o conteúdo principal
Insignia Sport NS-4V17 Scroll Wheel Replacement
O que você precisa
  1. Insignia Sport NS-4V17 Scroll Wheel Replacement, Battery: passo 1, imagem 1 %32
    • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  2. Insignia Sport NS-4V17 Scroll Wheel Replacement: passo 2, imagem 1 %32 Insignia Sport NS-4V17 Scroll Wheel Replacement: passo 2, imagem 2 %32
    • Detach the back cover by carefully pulling up and out on the back plastic casing.
    • Do not pull apart the red wire connecting the battery to the device.
  3. Insignia Sport NS-4V17 Scroll Wheel Replacement: passo 3, imagem 1 %32
    • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Be careful to not tear the wires while opening the case.
  4. Insignia Sport NS-4V17 Scroll Wheel Replacement: passo 4, imagem 1 %32
    • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Do not disconnect wires from plastic connector.
  5. Insignia Sport NS-4V17 Scroll Wheel Replacement, Front Case Cover: passo 5, imagem 1 %32 Insignia Sport NS-4V17 Scroll Wheel Replacement, Front Case Cover: passo 5, imagem 2 %32
    • Remove the four corner plastic covers on the back of the device using the plastic opening tool.
  6. Insignia Sport NS-4V17 Scroll Wheel Replacement: passo 6, imagem 1 %32
    • Using a Philips #00 screwdriver remove all four 4.5mm corner screws located underneath the corner pads.
  7. Insignia Sport NS-4V17 Scroll Wheel Replacement: passo 7, imagem 1 %32 Insignia Sport NS-4V17 Scroll Wheel Replacement: passo 7, imagem 2 %32 Insignia Sport NS-4V17 Scroll Wheel Replacement: passo 7, imagem 3 %32
    • Carefully wedge the plastic opening tool into either long side of the device.
    • Slowly move the plastic opening tool along the side of the device, separating the front and back case covers.
    • Repeat these steps on the other side of the device.
  8. Insignia Sport NS-4V17 Scroll Wheel Replacement: passo 8, imagem 1 %32
    • Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
  9. Insignia Sport NS-4V17 Scroll Wheel Replacement, Scroll Wheel: passo 9, imagem 1 %32
    • Remove the white plastic ring from around the scroll wheel using your fingers.
  10. Insignia Sport NS-4V17 Scroll Wheel Replacement: passo 10, imagem 1 %32 Insignia Sport NS-4V17 Scroll Wheel Replacement: passo 10, imagem 2 %32 Insignia Sport NS-4V17 Scroll Wheel Replacement: passo 10, imagem 3 %32
    • Insert the plastic opening tool underneath any side of the scroll wheel.
    • Slowly lift up on the plastic opening tool and the scroll wheel will come off.
Conclusão
Wesley Ballar
Membro desde: 04/18/13
88 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 12-36, Amido Spring 2013 Membro de Cal Poly, Team 12-36, Amido Spring 2013
CPSU-AMIDO-S13S12G36
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 449
