Introdução
Can't identify the source of your problem and suspect that the motherboard has something to do with it? This guide will show you how to remove the motherboard. Buckle down because this is the longest guide.
O que você precisa
Remove the four corner plastic covers on the back of the device using the plastic opening tool.
Remove the white plastic ring from around the scroll wheel with your fingers.
Uma outra pessoa concluiu este guia.
