Ir para o conteúdo principal
Insignia Sport NS-4V17 Motherboard Replacement
O que você precisa
  1. Insignia Sport NS-4V17 Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  2. Insignia Sport NS-4V17 Motherboard Replacement: passo 2, imagem 1 %32 Insignia Sport NS-4V17 Motherboard Replacement: passo 2, imagem 2 %32
    • Detach the back cover by carefully pulling up and out on the back plastic casing.
    • Do not pull apart the red wire connecting the battery to the device.
  3. Insignia Sport NS-4V17 Motherboard Replacement: passo 3, imagem 1 %32
    • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Be careful to not tear the wires while opening the case.
  4. Insignia Sport NS-4V17 Motherboard Replacement: passo 4, imagem 1 %32
    • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Do not disconnect wires from plastic connector.
  5. Insignia Sport NS-4V17 Motherboard Replacement, Front Case Cover: passo 5, imagem 1 %32 Insignia Sport NS-4V17 Motherboard Replacement, Front Case Cover: passo 5, imagem 2 %32
    • Remove the four corner plastic covers on the back of the device using the plastic opening tool.
  6. Insignia Sport NS-4V17 Motherboard Replacement: passo 6, imagem 1 %32
    • Using a Philips #00 screwdriver remove all four 4.5mm corner screws located underneath the corner pads.
  7. Insignia Sport NS-4V17 Motherboard Replacement: passo 7, imagem 1 %32 Insignia Sport NS-4V17 Motherboard Replacement: passo 7, imagem 2 %32 Insignia Sport NS-4V17 Motherboard Replacement: passo 7, imagem 3 %32
    • Carefully wedge the plastic opening tool into either long side of the device.
    • Slowly move the plastic opening tool along the side of the device, separating the front and back case covers.
    • Repeat these steps on the other side of the device.
  8. Insignia Sport NS-4V17 Motherboard Replacement: passo 8, imagem 1 %32
    • Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
  9. Insignia Sport NS-4V17 Motherboard Replacement, Motherboard: passo 9, imagem 1 %32
    • Remove the white plastic ring from around the scroll wheel with your fingers.
  10. Insignia Sport NS-4V17 Motherboard Replacement: passo 10, imagem 1 %32
    • Hold the sides of the device firmly with one hand.
    • Push down on the black favorite switch with your other hand so that it is pushed into the case.
  11. Insignia Sport NS-4V17 Motherboard Replacement: passo 11, imagem 1 %32 Insignia Sport NS-4V17 Motherboard Replacement: passo 11, imagem 2 %32
    • With the component pushed in, lift up the top of the motherboard from the case.
    • Pull the motherboard from the top so that the audio jack and usb input are removed from the case socket.
Conclusão
Uma outra pessoa concluiu este guia.
Wesley Ballar
Membro desde: 04/18/13
88 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 12-36, Amido Spring 2013 Membro de Cal Poly, Team 12-36, Amido Spring 2013
CPSU-AMIDO-S13S12G36
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 468
