Introdução
Does your device not turn on or does the power run out quickly? It is probably the result of a dysfunctional battery. This guide will show you how to remove your battery for a replacement. Be aware that this guide has some steps that can possibly damage the device.
Peças
Não são necessárias peças.
  1. Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
    • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  2. Detach the back cover by carefully pulling up and out on the back plastic casing. Do not pull apart the red wire connecting the battery to the device.
    • Detach the back cover by carefully pulling up and out on the back plastic casing.
    • Do not pull apart the red wire connecting the battery to the device.
  3. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Be careful to not tear the wires while opening the case.
  5. Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Do not disconnect wires from plastic connector.
Conclusão
Uma outra pessoa concluiu este guia.
David Poltorak
4 reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 12-36, Amido Spring 2013 Membro de Cal Poly, Team 12-36, Amido Spring 2013
CPSU-AMIDO-S13S12G36
4 Membros
5 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Todo: 839
