Ir para o conteúdo principal
Insignia NSD9PDVD15 Screen Replacement
O que você precisa
  1. Insignia NSD9PDVD15 Screen Replacement, Screen: passo 1, imagem 1 %32 Insignia NSD9PDVD15 Screen Replacement, Screen: passo 1, imagem 2 %32
    • Slide the “Open” tab on the top of the device.
    • This will allow you to open the device.
  2. Insignia NSD9PDVD15 Screen Replacement: passo 2, imagem 1 %32
    • Remove the six Phillips #00 screws from the screen casing.
    • To access two of the screws, first remove 2 small, flat rubber circles from the corners of the screen casing. Use a spudger if necessary.
  3. Insignia NSD9PDVD15 Screen Replacement: passo 3, imagem 1 %32
    • Remove the two screws from the hinge that holds together the screen casing and the disk panel.
    • Abruptly opening the device too wide will break the hinge. To fully access the hinge screws, firmly but gently open the device wider.
  4. Insignia NSD9PDVD15 Screen Replacement: passo 4, imagem 1 %32
    • Insert the plastic opening tool into the rectangular holes and pry open in order to access the interior of the screen casing.
    • Remove the four screws and corresponding washers from the edges of the screen.
    • Use a plastic opening tool to prop open if necessary.
  5. Insignia NSD9PDVD15 Screen Replacement: passo 5, imagem 1 %32
    • Remove the eight screws from the green motherboard.
  6. Insignia NSD9PDVD15 Screen Replacement: passo 6, imagem 1 %32
    • Unplug the red wires from the motherboard by gently pulling them off.
    • Then remove the screen.
  7. Insignia NSD9PDVD15 Screen Replacement: passo 7, imagem 1 %32
    • Set the new screen in place.
Conclusão
Jen Rodas
Membro desde: 09/30/15
1 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 2-5, Garvin Fall 2015 Membro de Ohio State, Team 2-5, Garvin Fall 2015
OSU-GARVIN-F15S2G5
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 449
