Introdução
The Insignia 2-in-1 stick vacuum power button can suddenly stop working or become jammed. In either case, use this guide to fix or replace the power button.
O que você precisa
Remove the four 12mm Phillips screws , and the one large 32mm Phillips head bolt from the vacuum handle.
Pull up on the back cover of the vacuum handle and remove it.
Quase terminado!
Conclusão
