Pular para o conteúdo principal
Introdução
The Insignia 2-in-1 stick vacuum power button can suddenly stop working or become jammed. In either case, use this guide to fix or replace the power button.
Peças
Nenhum componente especificado.
  1. Remove the four 12mm Phillips screws , and the one large 32mm Phillips head bolt from the vacuum handle. Pull up on the back cover of the vacuum handle and remove it. Pull up on the back cover of the vacuum handle and remove it.
    • Remove the four 12mm Phillips screws , and the one large 32mm Phillips head bolt from the vacuum handle.
    • Pull up on the back cover of the vacuum handle and remove it.
  2. kits de reparo de baterias de iPhone
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  3. Remove the two 10mm Phillips #2  screws on the back of the green printed circuit board. If the circuit board needs to be replaced, locate where the two white wires are soldered to the board, and de-solder the connection. If the circuit board needs to be replaced, locate where the two white wires are soldered to the board, and de-solder the connection.
    • Remove the two 10mm Phillips #2 screws on the back of the green printed circuit board.
    • If the circuit board needs to be replaced, locate where the two white wires are soldered to the board, and de-solder the connection.
Conclusão
Thibaut Pillot
Membro desde: 15-02-2018
434 reputação
5 Guias de autoria
Equipe
USF Tampa, Team S16-G3, Boczar Spring 2018 Membro de USF Tampa, Team S16-G3, Boczar Spring 2018
USFT-BOCZAR-S18S16G3
4 Membros
6 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 50
