Ir para o conteúdo principal
Insignia NS-VCS14SL7 Power Button Replacement
O que você precisa
  1. Insignia NS-VCS14SL7 Power Button Replacement, Battery: passo 1, imagem 1 %32 Insignia NS-VCS14SL7 Power Button Replacement, Battery: passo 1, imagem 2 %32
    • Push down the black button to release the dust cup.
    • Pull the dust cup up and away from handheld portion to remove.
  2. Insignia NS-VCS14SL7 Power Button Replacement: passo 2, imagem 1 %32 Insignia NS-VCS14SL7 Power Button Replacement: passo 2, imagem 2 %32 Insignia NS-VCS14SL7 Power Button Replacement: passo 2, imagem 3 %32
    • Remove the five 12.0 mm screws on the back of the handheld portion using the Phillips #2 screwdriver.
    • Lift the silver cover off of the black body of the handheld portion to expose the battery and wiring.
  3. Insignia NS-VCS14SL7 Power Button Replacement: passo 3, imagem 1 %32 Insignia NS-VCS14SL7 Power Button Replacement: passo 3, imagem 2 %32
    • Pull apart the red and black wires.
    • Do so for all of the wires. (Red x1, Black x2)
  4. Insignia NS-VCS14SL7 Power Button Replacement: passo 4, imagem 1 %32
    • Remove the tape holding the battery to the black housing.
    • Slide the entire battery bundle out.
  5. Insignia NS-VCS14SL7 Power Button Replacement, Handheld Vacuum Power Button: passo 5, imagem 1 %32
    • Remove motor and impeller housing to gain access to power button.
  6. Insignia NS-VCS14SL7 Power Button Replacement: passo 6, imagem 1 %32 Insignia NS-VCS14SL7 Power Button Replacement: passo 6, imagem 2 %32
    • Pry upwards on the retaining clip with black plastic spudger and pull to remove the 5 pin connector.
  7. Insignia NS-VCS14SL7 Power Button Replacement: passo 7, imagem 1 %32 Insignia NS-VCS14SL7 Power Button Replacement: passo 7, imagem 2 %32
    • Remove the two 10mm Philips #2 screws holding the brown printed circuit board to the vacuum.
    • Remove brown printed circuit board.
    • Pull up on clear plastic power button assembly to remove.
Conclusão
Thibaut Pillot
Membro desde: 02/15/18
434 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S16-G3, Boczar Spring 2018 Membro de USF Tampa, Team S16-G3, Boczar Spring 2018
USFT-BOCZAR-S18S16G3
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 11
Duração total: 213
