Ir para o conteúdo principal
Introdução
The Insignia 2-in-1 Handheld/Stick vacuum, over time, will lose its ability to work for extended amounts of time. Use this guide to access the battery for replacement and troubleshooting.
Peças
Nenhum componente especificado.
  1. Push down the black button to release the dust cup. Pull the dust cup up and away from handheld portion to remove.
    • Push down the black button to release the dust cup.
    • Pull the dust cup up and away from handheld portion to remove.
  2. Remove the five 12.0 mm screws on the back of the handheld portion using the Phillips #2 screwdriver. Lift the silver cover off of the black body of the handheld portion to expose the battery and wiring. Lift the silver cover off of the black body of the handheld portion to expose the battery and wiring.
    • Remove the five 12.0 mm screws on the back of the handheld portion using the Phillips #2 screwdriver.
    • Lift the silver cover off of the black body of the handheld portion to expose the battery and wiring.
  3. Pull apart the red and black wires. Do so for all of the wires. (Red x1, Black x2)
    • Pull apart the red and black wires.
    • Do so for all of the wires. (Red x1, Black x2)
  4. Remove the tape holding the battery to the black housing.
    • Remove the tape holding the battery to the black housing.
    • Slide the entire battery bundle out.
Conclusão
Uma outra pessoa concluiu este guia.
Trevor Rau
Membro desde: 15/02/2018
270 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S16-G3, Boczar Spring 2018 Membro de USF Tampa, Team S16-G3, Boczar Spring 2018
USFT-BOCZAR-S18S16G3
4 Membros
6 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 306
