Introdução
This guide will take you through the process of replacing the power cord of the Insignia NS-HTMC01-B.
O que você precisa
Flip the device over so the back panel faces up.
Unscrew the four screws counter-clockwise from the back panel using a 4mm Phillips screwdriver.
Use a Phillips #2 screwdriver to remove the two 1.7mm screws from the white triangular piece covering the power cord.
Quase terminado!
Conclusão
