Ir para o conteúdo principal
Insignia NS-HTMC01-B Power Cord Replacement
O que você precisa
  1. Insignia NS-HTMC01-B Power Cord Replacement, Front Case: passo 1, imagem 1 %32 Insignia NS-HTMC01-B Power Cord Replacement, Front Case: passo 1, imagem 2 %32 Insignia NS-HTMC01-B Power Cord Replacement, Front Case: passo 1, imagem 3 %32
    • Flip the device over so the back panel faces up.
    • Unscrew the four screws counter-clockwise from the back panel using a 4mm Phillips screwdriver.
    • You may want to use a flashlight during this step, as the screws are hard to see.
    • Make sure to firmly connect your screwdriver with the head of the screw. A loose connection can strip the screw head, making the screws nearly impossible to remove.
  2. Insignia NS-HTMC01-B Power Cord Replacement: passo 2, imagem 1 %32
    • Take the screws out and set them aside.
    • Be sure to set them somewhere flat, so they don't roll away.
    • Gently pull the front panel and back panel apart to open the device.
  3. Insignia NS-HTMC01-B Power Cord Replacement, Power Cord: passo 3, imagem 1 %32
    • Use a Phillips #2 screwdriver to remove the two 1.7mm screws from the white triangular piece covering the power cord.
  4. Insignia NS-HTMC01-B Power Cord Replacement: passo 4, imagem 1 %32
    • Disconnect all of the blue wires. There should be 3 separate blue-wire connections.
  5. Insignia NS-HTMC01-B Power Cord Replacement: passo 5, imagem 1 %32
    • Disconnect the second black wire from the rectangular piece above the Tip-Over Safety Switch.
    • Remove power cord.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 198
