Ir para o conteúdo principal
Insignia NS-HTMC01-B Power Button Replacement
O que você precisa
  1. Insignia NS-HTMC01-B Power Button Replacement, Power Button: passo 1, imagem 1 %32
    • Flip your device over so the bottom panel faces you. You should see a hole containing a screw in each corner of the device.
    • Insert a 4-inch Phillips #1 screwdriver into each hole until connected with the 20 millimeter, sharp-point screw.
  2. Insignia NS-HTMC01-B Power Button Replacement: passo 2, imagem 1 %32
    • Find the power switch, located inside the heater on the bottom left corner.
  3. Insignia NS-HTMC01-B Power Button Replacement: passo 3, imagem 1 %32
    • Using a Phillips #1 screwdriver, unscrew the two 7 millimeter screws attaching the power switch to the power button.
  4. Insignia NS-HTMC01-B Power Button Replacement: passo 4, imagem 1 %32 Insignia NS-HTMC01-B Power Button Replacement: passo 4, imagem 2 %32
    • Find the clips holding the power button in place.
    • Press down on the clips to remove the button.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 135
