Introdução
This guide will help you replace a broken or damaged internal fan within your Insignia NS-HTMC01-B ceramic heater. A broken or damaged fan can cause your heater to put out lower amounts of heat, or no heat at all.
O que você precisa
Flip your device over so the back panel faces you. You should see a hole containing a screw in each corner of the device.
Insert a 4-inch Phillips #1 screwdriver into each hole until connected with the 20 millimeter, sharp-point screw.
Uma outra pessoa concluiu este guia.
