Ir para o conteúdo principal
Insignia NS-F12R6-SS Oscillation Arm Replacement
O que você precisa
  1. Insignia NS-F12R6-SS Oscillation Arm Replacement, Front Cage: passo 1, imagem 1 %32 Insignia NS-F12R6-SS Oscillation Arm Replacement, Front Cage: passo 1, imagem 2 %32
    • Unplug your fan.
    • Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
  2. Insignia NS-F12R6-SS Oscillation Arm Replacement: passo 2, imagem 1 %32
    • Remove the ring that runs around the edge of the fan cage.
  3. Insignia NS-F12R6-SS Oscillation Arm Replacement: passo 3, imagem 1 %32
    • Remove the front of the fan cage.
  4. Insignia NS-F12R6-SS Oscillation Arm Replacement, Fan Blade: passo 4, imagem 1 %32
    • Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
  5. Insignia NS-F12R6-SS Oscillation Arm Replacement: passo 5, imagem 1 %32
    • Take caution when removing the fan blades. They can be sharp!
    • Slide the fan blade off the end of the rotor.
  6. Insignia NS-F12R6-SS Oscillation Arm Replacement, Back Cage: passo 6, imagem 1 %32
    • Unscrew the four 8 mm bolts that fasten the back of the fan cage back to the motor housing with a Phillips #3 screwdriver.
  7. Insignia NS-F12R6-SS Oscillation Arm Replacement: passo 7, imagem 1 %32
    • Pull the back cage off.
  8. Insignia NS-F12R6-SS Oscillation Arm Replacement, Oscillation Button: passo 8, imagem 1 %32 Insignia NS-F12R6-SS Oscillation Arm Replacement, Oscillation Button: passo 8, imagem 2 %32
    • Unscrew the 10 mm screw in the center hole of the oscillation knob with a Phillips #3 screwdriver.
  9. Insignia NS-F12R6-SS Oscillation Arm Replacement: passo 9, imagem 1 %32
    • Remove the oscillation knob.
  10. Insignia NS-F12R6-SS Oscillation Arm Replacement, Motor Housing: passo 10, imagem 1 %32
    • Use your fingers to gently pull the power knob directly away from the motor housing.
  11. Insignia NS-F12R6-SS Oscillation Arm Replacement: passo 11, imagem 1 %32
    • Unscrew the flat 17 mm nut fastened at the bottom of the power knob with a small crescent wrench.
  12. Insignia NS-F12R6-SS Oscillation Arm Replacement: passo 12, imagem 1 %32 Insignia NS-F12R6-SS Oscillation Arm Replacement: passo 12, imagem 2 %32
    • Remove the four 6 mm bolts and small washers that secure the front face of the motor housing with a Phillips #3 screwdriver and remove the washers.
  13. Insignia NS-F12R6-SS Oscillation Arm Replacement: passo 13, imagem 1 %32
    • Pull the front face of the motor housing off toward the front of the rotor.
  14. Insignia NS-F12R6-SS Oscillation Arm Replacement: passo 14, imagem 1 %32 Insignia NS-F12R6-SS Oscillation Arm Replacement: passo 14, imagem 2 %32
    • Remove the 10 mm triangular-headed bolt with a Phillips #3 screwdriver.
  15. Insignia NS-F12R6-SS Oscillation Arm Replacement: passo 15, imagem 1 %32
    • Slide the back end of the motor housing away from the front of the rotor.
  16. Insignia NS-F12R6-SS Oscillation Arm Replacement: passo 16, imagem 1 %32
    • Remove the small piece of paper hanging on the power button.
  17. Insignia NS-F12R6-SS Oscillation Arm Replacement, Oscillation Arm: passo 17, imagem 1 %32 Insignia NS-F12R6-SS Oscillation Arm Replacement, Oscillation Arm: passo 17, imagem 2 %32
    • Using a Phillips #3 screwdriver, unscrew the the 16 mm long screw fastening the oscillation arm to the lower oscillation gear screw.
  18. Insignia NS-F12R6-SS Oscillation Arm Replacement: passo 18, imagem 1 %32 Insignia NS-F12R6-SS Oscillation Arm Replacement: passo 18, imagem 2 %32
    • Using a Phillips #3 screwdriver, unscrew and remove the 4 mm long bolt on the front face of the base that fastens the motor assembly to the base bolt.
  19. Insignia NS-F12R6-SS Oscillation Arm Replacement: passo 19, imagem 1 %32
    • Remove the fan motor assembly from the base.
  20. Insignia NS-F12R6-SS Oscillation Arm Replacement: passo 20, imagem 1 %32 Insignia NS-F12R6-SS Oscillation Arm Replacement: passo 20, imagem 2 %32
    • Using a Phillips #3 screwdriver, unscrew the 15 mm long bolt fastening the oscillation arm to the fan base bolt.
  21. Insignia NS-F12R6-SS Oscillation Arm Replacement: passo 21, imagem 1 %32
    • Remove the oscillation arm.
Conclusão
Uma outra pessoa concluiu este guia.
Hank
Membro desde: 09/17/18
1.142 Reputação
Autoria de 8 guias
Equipe
CSU Fullerton, Team S2-G1, Bruce Fall 2018 Membro de CSU Fullerton, Team S2-G1, Bruce Fall 2018
CSUF-BRUCE-F18S2G1
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 461
