Ir para o conteúdo principal
Insignia NS-DS9PDVD15 Disc Reader Replacement
O que você precisa
  1. Insignia NS-DS9PDVD15 Disc Reader Replacement, Bottom Cover: passo 1, imagem 1 %32 Insignia NS-DS9PDVD15 Disc Reader Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Turn the power off. Slide the power button to OFF.
  2. Insignia NS-DS9PDVD15 Disc Reader Replacement: passo 2, imagem 1 %32 Insignia NS-DS9PDVD15 Disc Reader Replacement: passo 2, imagem 2 %32
    • Unplug AC adapter from car cigarette lighter.
  3. Insignia NS-DS9PDVD15 Disc Reader Replacement: passo 3, imagem 1 %32
    • Make sure there is no DVD or CD in the disc tray
  4. Insignia NS-DS9PDVD15 Disc Reader Replacement: passo 4, imagem 1 %32 Insignia NS-DS9PDVD15 Disc Reader Replacement: passo 4, imagem 2 %32
    • Unscrew the nine 9mm screws with a JIS #000 screwdriver.
  5. Insignia NS-DS9PDVD15 Disc Reader Replacement: passo 5, imagem 1 %32 Insignia NS-DS9PDVD15 Disc Reader Replacement: passo 5, imagem 2 %32 Insignia NS-DS9PDVD15 Disc Reader Replacement: passo 5, imagem 3 %32
    • Pry off back panel with prying tool, then remove by hand.
  6. Insignia NS-DS9PDVD15 Disc Reader Replacement, Disc Tray: passo 6, imagem 1 %32 Insignia NS-DS9PDVD15 Disc Reader Replacement, Disc Tray: passo 6, imagem 2 %32
    • After the back is removed and the disk tray is loose from the bottom, locate the two, 3 mm screws that hold the tray to the hinge.
    • Unscrew them with the JIS #000 screwdriver.
  7. Insignia NS-DS9PDVD15 Disc Reader Replacement: passo 7, imagem 1 %32
    • Slide the tray up and off of the hinge completely.
  8. Insignia NS-DS9PDVD15 Disc Reader Replacement, Disc Reader: passo 8, imagem 1 %32
    • Locate the disk reader, it will be right under the disk chamber.
  9. Insignia NS-DS9PDVD15 Disc Reader Replacement: passo 9, imagem 1 %32
    • Pick it straight up, it should slide off the three pegs holding it in place, if not, wiggle each peg individually.
  10. Insignia NS-DS9PDVD15 Disc Reader Replacement: passo 10, imagem 1 %32
    • Once you have it loose, unplug it from the PC Board. Then the disk reader can be removed.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 581
