Ir para o conteúdo principal
Insignia NS-DS9PDVD15 Screen Replacement
O que você precisa
  1. Insignia NS-DS9PDVD15  Screen Replacement, Bottom Cover: passo 1, imagem 1 %32 Insignia NS-DS9PDVD15  Screen Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Turn the power off. Slide the power button to OFF.
  2. Insignia NS-DS9PDVD15  Screen Replacement: passo 2, imagem 1 %32 Insignia NS-DS9PDVD15  Screen Replacement: passo 2, imagem 2 %32
    • Unplug AC adapter from car cigarette lighter.
  3. Insignia NS-DS9PDVD15  Screen Replacement: passo 3, imagem 1 %32
    • Make sure there is no DVD or CD in the disc tray
  4. Insignia NS-DS9PDVD15  Screen Replacement: passo 4, imagem 1 %32 Insignia NS-DS9PDVD15  Screen Replacement: passo 4, imagem 2 %32
    • Unscrew the nine 9mm screws with a JIS #000 screwdriver.
  5. Insignia NS-DS9PDVD15  Screen Replacement: passo 5, imagem 1 %32 Insignia NS-DS9PDVD15  Screen Replacement: passo 5, imagem 2 %32 Insignia NS-DS9PDVD15  Screen Replacement: passo 5, imagem 3 %32
    • Pry off back panel with prying tool, then remove by hand.
  6. Insignia NS-DS9PDVD15  Screen Replacement, Disc Tray: passo 6, imagem 1 %32 Insignia NS-DS9PDVD15  Screen Replacement, Disc Tray: passo 6, imagem 2 %32
    • After the back is removed and the disk tray is loose from the bottom, locate the two, 3 mm screws that hold the tray to the hinge.
    • Unscrew them with the JIS #000 screwdriver.
  7. Insignia NS-DS9PDVD15  Screen Replacement: passo 7, imagem 1 %32
    • Slide the tray up and off of the hinge completely.
  8. Insignia NS-DS9PDVD15  Screen Replacement, Screen: passo 8, imagem 1 %32
    • After the bottom cover and disk tray have been removed, remove the back panel from the top half.
    • There are six, 9 mm screws on the bottom cover and 2 screws on the hinge. Remove them with the JIS #000 screwdriver.
  9. Insignia NS-DS9PDVD15  Screen Replacement: passo 9, imagem 1 %32 Insignia NS-DS9PDVD15  Screen Replacement: passo 9, imagem 2 %32
    • Once all the screws are removed, pry off the cover with the pry tool.
    • You'll see the PC board, back of the speakers, and the back of the screen.
  10. Insignia NS-DS9PDVD15  Screen Replacement: passo 10, imagem 1 %32 Insignia NS-DS9PDVD15  Screen Replacement: passo 10, imagem 2 %32
    • Remove the ribbon cable carefully with the pry tool.
    • First, push out the black portion.
  11. Insignia NS-DS9PDVD15  Screen Replacement: passo 11, imagem 1 %32 Insignia NS-DS9PDVD15  Screen Replacement: passo 11, imagem 2 %32
    • Next, push out the 'ribbon' with the pry tool.
  12. Insignia NS-DS9PDVD15  Screen Replacement: passo 12, imagem 1 %32 Insignia NS-DS9PDVD15  Screen Replacement: passo 12, imagem 2 %32
    • Unscrew the corners of screen with the JIS #000 screwdriver. There are four, 6 mm screws with washers.
  13. Insignia NS-DS9PDVD15  Screen Replacement: passo 13, imagem 1 %32 Insignia NS-DS9PDVD15  Screen Replacement: passo 13, imagem 2 %32
    • After the screws and washers are removed, you can lift the screen off with the pry tool.
Conclusão
Um comentário
what is the model of the LCD Panel?
Justin Frost - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 706
