Introdução
This guide shows how to replace the screen for the Insignia NS-DS9PDVD15.
O que você precisa
After the back is removed and the disk tray is loose from the bottom, locate the two, 3 mm screws that hold the tray to the hinge.
Unscrew them with the JIS #000 screwdriver.
After the bottom cover and disk tray have been removed, remove the back panel from the top half.
There are six, 9 mm screws on the bottom cover and 2 screws on the hinge. Remove them with the JIS #000 screwdriver.
