Ir para o conteúdo principal
Insignia NS-D160A14 Motherboard Replacement
O que você precisa
  1. Insignia NS-D160A14 Motherboard Replacement, Outer Case: passo 1, imagem 1 %32
    • Unplug the power cord before proceeding to open the DVD player's enclosure.
    • Remove the two 7mm Phillips #2 screws from the back of the DVD player.
  2. Insignia NS-D160A14 Motherboard Replacement: passo 2, imagem 1 %32
    • Carefully lift the outer case up, starting from the back.
    • Removing the outer case may require some force, and you will need to get the case into an angled position compared to the rest of the DVD player before it can be completely separated.
  3. Insignia NS-D160A14 Motherboard Replacement, Front Panel: passo 3, imagem 1 %32 Insignia NS-D160A14 Motherboard Replacement, Front Panel: passo 3, imagem 2 %32 Insignia NS-D160A14 Motherboard Replacement, Front Panel: passo 3, imagem 3 %32
    • Unhook the 4 hooks on the main casing.
    • There is one hook on the top of the casing, one on the bottom, and one on each side.
    • These hooks are brittle and can easily break.
  4. Insignia NS-D160A14 Motherboard Replacement, Motherboard: passo 4, imagem 1 %32
    • Remove the central 7 mm screw holding the motherboard in place.
    • Be sure to ground yourself before manipulating the motherboard. A static shock could render one or more components on the motherboard useless.
  5. Insignia NS-D160A14 Motherboard Replacement: passo 5, imagem 1 %32
    • Disconnect the white power cord connector from the motherboard.
  6. Insignia NS-D160A14 Motherboard Replacement: passo 6, imagem 1 %32 Insignia NS-D160A14 Motherboard Replacement: passo 6, imagem 2 %32
    • Keeping the 8-pin connector as straight as possible, lift the motherboard out of case.
    • You may need to bend the side of the case slightly to give the motherboard room to be lifted out.
Conclusão
Uma outra pessoa concluiu este guia.
Ian Hanken
Membro desde: 07/20/16
516 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 910
