Ir para o conteúdo principal
Insignia NS-CSPBTHOL-R Speakers Replacement
O que você precisa
  1. Insignia NS-CSPBTHOL-R Speakers Replacement, Speakers: passo 1, imagem 1 %32
    • Insert the Spudger between the grated panel and the base of the speaker.
  2. Insignia NS-CSPBTHOL-R Speakers Replacement: passo 2, imagem 1 %32
    • Pull the grated panel off
  3. Insignia NS-CSPBTHOL-R Speakers Replacement: passo 3, imagem 1 %32
    • Remove the six 3mm screws using the J00 JIS screw bit. This will require a long, narrow screwdriver.
  4. Insignia NS-CSPBTHOL-R Speakers Replacement: passo 4, imagem 1 %32
    • Insert the Spudger between the corners of base and the face of the speaker to open the device.
    • The screw on the upper right corner may be difficult to take out. If you cannot take it out with a screwdriver, using force to pull the face of the speaker apart may break the plastic that surrounds the screw.
  5. Insignia NS-CSPBTHOL-R Speakers Replacement: passo 5, imagem 1 %32
    • Remove one speaker at a time
  6. Insignia NS-CSPBTHOL-R Speakers Replacement: passo 6, imagem 1 %32
    • Grab the back piece of the speaker and gently pull upward.
  7. Insignia NS-CSPBTHOL-R Speakers Replacement: passo 7, imagem 1 %32
    • Remove speakers gently one at a time.
  8. Insignia NS-CSPBTHOL-R Speakers Replacement: passo 8, imagem 1 %32 Insignia NS-CSPBTHOL-R Speakers Replacement: passo 8, imagem 2 %32 Insignia NS-CSPBTHOL-R Speakers Replacement: passo 8, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using blunted tip tweezers, squeeze and pull on the white plastic clip. This will separate the speaker's wires from the motherboard.
    • The wires are connected to the white plastic clip that is attached to the motherboard.
Conclusão
Lheessis Ruiz
Membro desde: 02/15/17
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 12-6, Eyestone Spring 2017 Membro de USF Tampa, Team 12-6, Eyestone Spring 2017
USFT-EYESTONE-S17S12G6
Membros da 3
Autoria de 4 guias
Um comentário
This is a good app really could help some people like myself. Thank you
rrguerrero7330 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 644
