Ir para o conteúdo principal
Insignia NS-CSPBTHOL-R Power Button Replacement
O que você precisa
  1. Insignia NS-CSPBTHOL-R Power Button Replacement, Battery: passo 1, imagem 1 %32
    • Push the Spudger into the crevice between the grated panel of the speaker and the base of the speaker.
    • Angle the spudger to create a separation between the grate and the base.
  2. Insignia NS-CSPBTHOL-R Power Button Replacement: passo 2, imagem 1 %32
    • Slide the spudger along the separation between the grate and the base of the speaker to loosen the grate. Do this to the entire perimeter of the speaker.
  3. Insignia NS-CSPBTHOL-R Power Button Replacement: passo 3, imagem 1 %32 Insignia NS-CSPBTHOL-R Power Button Replacement: passo 3, imagem 2 %32
    • Pull the grated panel off.
  4. Insignia NS-CSPBTHOL-R Power Button Replacement: passo 4, imagem 1 %32 Insignia NS-CSPBTHOL-R Power Button Replacement: passo 4, imagem 2 %32
    • Remove the six 3mm screws using the J00 JIS screw bit. This will require a long, narrow screwdriver.
  5. Insignia NS-CSPBTHOL-R Power Button Replacement: passo 5, imagem 1 %32 Insignia NS-CSPBTHOL-R Power Button Replacement: passo 5, imagem 2 %32
    • Push the spudger into the crevice between the base and the face of the speaker and create a separation.
    • Slide the spudger along the entire perimeter and gently pull off the face of the speaker.
    • The two parts are connected by wires, do not rip them apart.
  6. Insignia NS-CSPBTHOL-R Power Button Replacement: passo 6, imagem 1 %32
    • Use the spudger to release the battery by sliding it underneath the battery to create a separation.
    • Remove the battery.
  7. Insignia NS-CSPBTHOL-R Power Button Replacement: passo 7, imagem 1 %32 Insignia NS-CSPBTHOL-R Power Button Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Pull the motherboard from the base of the speaker.
    • Using tweezers, squeeze and pull on the white plastic clip that connects the battery wires to the motherboard.
    • Unclip the battery from the motherboard.
  8. Insignia NS-CSPBTHOL-R Power Button Replacement, Power Button: passo 8, imagem 1 %32 Insignia NS-CSPBTHOL-R Power Button Replacement, Power Button: passo 8, imagem 2 %32 Insignia NS-CSPBTHOL-R Power Button Replacement, Power Button: passo 8, imagem 3 %32
    • Using tweezers, detach the power button from the mother board.
Conclusão
Judith Villegas
Membro desde: 02/15/17
327 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 12-6, Eyestone Spring 2017 Membro de USF Tampa, Team 12-6, Eyestone Spring 2017
USFT-EYESTONE-S17S12G6
3 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 13
Ao todo: 741
