Ir para o conteúdo principal
Insignia NS-CLOPP2 Motherboard Replacement
O que você precisa
  1. Insignia NS-CLOPP2 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • First, remove the front screen. (See prerequisite screen removal guide.)
  2. Insignia NS-CLOPP2 Motherboard Replacement: passo 2, imagem 1 %32
    • Use the plastic opening tool to gently pry the motherboard forward and away from the rest of the device.
  3. Insignia NS-CLOPP2 Motherboard Replacement: passo 3, imagem 1 %32
    • Gently lift the motherboard up and out, making sure that you don't disassemble any of the wires in place by pulling too hard.
  4. Insignia NS-CLOPP2 Motherboard Replacement: passo 4, imagem 1 %32
    • To fully remove the motherboard from the clock, use wire cutters to carefully sever the connections between the motherboard and the wires attached.
    • To reassemble your device, follow these instructions in reverse order.
Conclusão
3 outras pessoas executaram este guia.
Dilini De Silva
Membro desde: 03/11/15
757 Reputação
Autoria de 5 guias
Equipe
Marist, Team 1-1, Laflen Spring 2015 Membro de Marist, Team 1-1, Laflen Spring 2015
MARS-LAFLEN-S15S1G1
Membros da 2
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 145
