Ir para o conteúdo principal
Insignia NS-CLOPP2 Batteries Replacement
O que você precisa
  1. Insignia NS-CLOPP2 Batteries Replacement, Batteries: passo 1, imagem 1 %32
    • Flip the clock over to expose the battery cover shown in the top left corner.
  2. Insignia NS-CLOPP2 Batteries Replacement: passo 2, imagem 1 %32
    • Remove the battery cover by gripping the grooves with your thumb and sliding the cover in the direction the arrow is pointing.
  3. Insignia NS-CLOPP2 Batteries Replacement: passo 3, imagem 1 %32
    • Carefully push the battery towards the spring, creating a space to grab the battery and pull it out. Safely discard the old batteries.
  4. Insignia NS-CLOPP2 Batteries Replacement: passo 4, imagem 1 %32
    • Insert new batteries by matching the (+) and (-) symbols on the battery with the corresponding symbols on the device battery cavity. Push each battery in by pressing towards the spring and snapping into place on the opposite end.
  5. Insignia NS-CLOPP2 Batteries Replacement: passo 5, imagem 1 %32
    • Once the batteries have been replaced, slide the battery cover on by pushing the cover opposite the arrow until it clicks into place.
Linha de Chegada
Dilini De Silva
Membro desde: 03/11/15
757 Reputação
Autoria de 5 guias
Equipe
Marist, Team 1-1, Laflen Spring 2015 Membro de Marist, Team 1-1, Laflen Spring 2015
MARS-LAFLEN-S15S1G1
Membros da 2
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 227
