O que você precisa
Follow steps on removing the motherboard as a prerequisite.
Gently move the motherboard back, revealing the thin black wire that is the antenna. The antenna wire is, on the outside, located on the lower, middle back. Follow the wire from the outside to the inside to make sure it's the correct one.
