Ir para o conteúdo principal
Insignia NS-CLIP02 Speaker replacement and troubleshooting
O que você precisa
  1. Insignia NS-CLIP02 Speaker replacement and troubleshooting, Motherboard: passo 1, imagem 1 %32
    • Set the clock radio on the work space so the bottom of the device is showing.
  2. Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 2, imagem 1 %32 Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 2, imagem 2 %32
    • Use a metal spudger to peel back the adhesive sticker on the bottom of the clock.
    • You should see a single screw beneath the sticker.
  3. Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 3, imagem 1 %32 Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 3, imagem 2 %32
    • Using a plastic opening tool, peel off the adhesive gel stoppers.
  4. Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 4, imagem 1 %32
    • Use a Phillips screwdriver to remove the six 11 mm screws on the bottom of the device.
  5. Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 5, imagem 1 %32
    • Remove the bottom cover from the device to reveal the motherboard.
  6. Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 6, imagem 1 %32
    • Use a Phillips screwdriver to remove the 9.5 mm screw located near the center of the motherboard.
  7. Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 7, imagem 1 %32
    • Lift the motherboard away from the device.
  8. Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 8, imagem 1 %32 Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 8, imagem 2 %32 Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 8, imagem 3 %32
    • Disconnect the four cables connecting the motherboard to the device.
  9. Insignia NS-CLIP02 Speaker replacement and troubleshooting, Speaker: passo 9, imagem 1 %32
    • Remove the three screws located along the center of the base.
  10. Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 10, imagem 1 %32 Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 10, imagem 2 %32
    • Remove the base from the display.
  11. Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 11, imagem 1 %32 Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 11, imagem 2 %32 Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 11, imagem 3 %32
    • Using a metal spudger, remove the plastic face plate from the display.
  12. Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 12, imagem 1 %32
    • With a phillips screwdriver, remove the six screws shown pictured to the left.
  13. Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 13, imagem 1 %32 Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 13, imagem 2 %32
    • Using the metal spudger, pry the speaker grilles from the display.
  14. Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 14, imagem 1 %32
    • Using the phillips screwdriver, remove the four screws pictured to the left.
  15. Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 15, imagem 1 %32
    • Separate the two pieces of the display as shown.
  16. Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 16, imagem 1 %32 Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 16, imagem 2 %32 Insignia NS-CLIP02 Speaker replacement and troubleshooting: passo 16, imagem 3 %32
    • You can see that there are several points where connections to the speaker are soldered.
    • If all connections are soldered then replacement may be necessary.
Conclusão
Aubrey
Membro desde: 02/24/15
214 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 9-3, Leahy Winter 2015 Membro de USF Tampa, Team 9-3, Leahy Winter 2015
USFT-LEAHY-W15S9G3
4 Membros
Autoria de 6 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 15
Ao todo: 206
