Introdução
The Insignia NS-CLIP02 can develop a problem with power auxiliary ports malfunctioning, but don’t worry. They’re replaceable! If your device is not charging, this may be a key indicator that the port needs to be replaced.
Use this simple step-by-step guide to replace your motherboard that contains the auxiliary port in 30 minutes or less.
O que você precisa
Quase terminado!
Conclusão
