Ir para o conteúdo principal
Insignia NS-CLIP02 Motherboard Replacement
O que você precisa
  1. Insignia NS-CLIP02 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Set the clock radio on the work space so the bottom of the device is showing.
  2. Insignia NS-CLIP02 Motherboard Replacement: passo 2, imagem 1 %32 Insignia NS-CLIP02 Motherboard Replacement: passo 2, imagem 2 %32
    • Use a metal spudger to peel back the adhesive sticker on the bottom of the clock.
    • You should see a single screw beneath the sticker.
  3. Insignia NS-CLIP02 Motherboard Replacement: passo 3, imagem 1 %32 Insignia NS-CLIP02 Motherboard Replacement: passo 3, imagem 2 %32
    • Using a plastic opening tool, peel off the adhesive gel stoppers.
  4. Insignia NS-CLIP02 Motherboard Replacement: passo 4, imagem 1 %32
    • Use a Phillips screwdriver to remove the six 11 mm screws on the bottom of the device.
  5. Insignia NS-CLIP02 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the bottom cover from the device to reveal the motherboard.
  6. Insignia NS-CLIP02 Motherboard Replacement: passo 6, imagem 1 %32
    • Use a Phillips screwdriver to remove the 9.5 mm screw located near the center of the motherboard.
  7. Insignia NS-CLIP02 Motherboard Replacement: passo 7, imagem 1 %32
    • Lift the motherboard away from the device.
  8. Insignia NS-CLIP02 Motherboard Replacement: passo 8, imagem 1 %32 Insignia NS-CLIP02 Motherboard Replacement: passo 8, imagem 2 %32 Insignia NS-CLIP02 Motherboard Replacement: passo 8, imagem 3 %32
    • Disconnect the four cables connecting the motherboard to the device.
Conclusão
Erik
Membro desde: 02/19/15
405 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 9-3, Leahy Winter 2015 Membro de USF Tampa, Team 9-3, Leahy Winter 2015
USFT-LEAHY-W15S9G3
4 Membros
Autoria de 6 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 16
Ao todo: 190
