Ir para o conteúdo principal
Insignia NS-CLIP02 Keypad Replacement
O que você precisa
  1. Insignia NS-CLIP02 Keypad Replacement, Keypad: passo 1, imagem 1 %32
    • Locate the bottom of the device.
  2. Insignia NS-CLIP02 Keypad Replacement: passo 2, imagem 1 %32
    • Begin by using a metal spudger to peel back the adhesive sticker and locate the 11mm screw beneath the sticker.
  3. Insignia NS-CLIP02 Keypad Replacement: passo 3, imagem 1 %32
    • Locate the 11mm screw beneath the sticker.
  4. Insignia NS-CLIP02 Keypad Replacement: passo 4, imagem 1 %32
    • Using a plastic spudger, peel off the adhesive gel stoppers.
  5. Insignia NS-CLIP02 Keypad Replacement: passo 5, imagem 1 %32
    • Continue peeling the rest of the gel stoppers from the bottom of the device.
  6. Insignia NS-CLIP02 Keypad Replacement: passo 6, imagem 1 %32
    • Begin unscrewing the six 11mm screws with a Phillips head screw driver.
  7. Insignia NS-CLIP02 Keypad Replacement: passo 7, imagem 1 %32
    • Once you peel off the bottom from the device, you will see the motherboard.
  8. Insignia NS-CLIP02 Keypad Replacement: passo 8, imagem 1 %32
    • Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
  9. Insignia NS-CLIP02 Keypad Replacement: passo 9, imagem 1 %32
    • Lift the motherboard from the device.
  10. Insignia NS-CLIP02 Keypad Replacement: passo 10, imagem 1 %32
    • Locate the four plugs connecting the motherboard to the rest of the device.
  11. Insignia NS-CLIP02 Keypad Replacement: passo 11, imagem 1 %32
    • Begin with removing the plug to your left.
  12. Insignia NS-CLIP02 Keypad Replacement: passo 12, imagem 1 %32
    • Remove the plug to your right from the motherboard.
  13. Insignia NS-CLIP02 Keypad Replacement: passo 13, imagem 1 %32
    • Remove the plug in the front of the lcd screen plug.
  14. Insignia NS-CLIP02 Keypad Replacement: passo 14, imagem 1 %32
    • Remove the LCD screen plug last. Then, follow the following instructions in reverse, replacing the old motherboard with the new one to fix the keypad.
Conclusão
Erik
Membro desde: 02/19/15
405 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 9-3, Leahy Winter 2015 Membro de USF Tampa, Team 9-3, Leahy Winter 2015
USFT-LEAHY-W15S9G3
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 137
