O que você precisa
Turn the boombox around to see the back, and then flip it upside down.
Insert a 2.5mm flathead driver into the two holes next to the battery compartment.
Turn the driver counterclockwise several times to loosen and pull out the 17mm screw.
Face the bottom of the opened boombox, and detach the front panel from the back in the following order:
Unplug the 4 wires (1 red, 2 black, 1 white) from the yellow motherboard on the front panel, by pulling upwards.
Pull the black tape attached to the white plug on the yellow motherboard by tugging upwards.
Detach the thicker, white and pink cord on the smaller yellow plate on the front panel by pulling away.
