Introdução
This product plays both CD's and Cassettes as well as AM/FM radio stations.
Before attempting this replacement, make sure to use a anti-static strap to prevent circuit damages to your device.
O que você precisa
Turn the boombox around to see the back, and then flip it upside down.
Insert a 2.5mm flathead driver into the two holes next to the battery compartment.
Turn the driver counterclockwise several times to loosen and pull out the 17mm screw.
Unplug the red and black wires from the large yellow motherboard by pulling upwards.
