Ir para o conteúdo principal
Insignia NS-B4111 Antenna Replacement
O que você precisa
  1. Insignia NS-B4111 Antenna Replacement, Battery: passo 1, imagem 1 %32 Insignia NS-B4111 Antenna Replacement, Battery: passo 1, imagem 2 %32
    • Unplug and remove the power cord. Turn the boombox upside down.
    • Grip the sides of the case and use your thumbs to pop open the battery cover.
  2. Insignia NS-B4111 Antenna Replacement: passo 2, imagem 1 %32 Insignia NS-B4111 Antenna Replacement: passo 2, imagem 2 %32
    • Pry out the batteries with your fingers.
  3. Insignia NS-B4111 Antenna Replacement, External Antenna: passo 3, imagem 1 %32
    • Set the boombox upright. Remove the 4mm screw and the two 6mm washers with the Phillips PH1 screwdriver.
    • Remove the external antenna.
  4. Insignia NS-B4111 Antenna Replacement, Casing: passo 4, imagem 1 %32
    • Turn the boombox upside down again. With the Phillips PH1 or the Flathead #3 screwdriver, remove the three 14mm black screws.
    • Remove the four 18mm chrome screws with the Phillips PH1 screwdriver.
  5. Insignia NS-B4111 Antenna Replacement: passo 5, imagem 1 %32 Insignia NS-B4111 Antenna Replacement: passo 5, imagem 2 %32
    • Gently remove the bottom half of the casing from the top half of the casing.
    • The antenna base is connected to the motherboard by a red wire. This wire will prevent the two halves from separating completely.
  6. Insignia NS-B4111 Antenna Replacement, Antenna Base: passo 6, imagem 1 %32 Insignia NS-B4111 Antenna Replacement, Antenna Base: passo 6, imagem 2 %32
    • Remove the 10mm chrome screw from the antenna base with the Phillips PH1 screwdriver. Remove the antenna base from the casing.
    • This red wire will now be loose and you can move it out of the antenna base slot.
Conclusão
Kristin Yoshioka
Membro desde: 09/21/16
984 Reputação
Autoria de 9 guias
Equipe
UC Davis, Team 1-5, Oliver Fall 2016 Membro de UC Davis, Team 1-5, Oliver Fall 2016
UCD-OLIVER-F16S1G5
5 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 930
