Ir para o conteúdo principal
Insignia NS-B2110 Battery Replacement
O que você precisa
  1. Insignia NS-B2110 Battery Replacement, Battery: passo 1, imagem 1 %32 Insignia NS-B2110 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
  2. Insignia NS-B2110 Battery Replacement: passo 2, imagem 1 %32 Insignia NS-B2110 Battery Replacement: passo 2, imagem 2 %32
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
Conclusão
Daniel Hodges
Membro desde: 10/14/13
301 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 4-31, Amido Fall 2013 Membro de Cal Poly, Team 4-31, Amido Fall 2013
CPSU-AMIDO-F13S4G31
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 349
