Ir para o conteúdo principal
Insignia NS-15MS0832B Speaker Replacement
O que você precisa
  1. Insignia NS-15MS0832B Speaker  Replacement, Speakers: passo 1, imagem 1 %32
    • Begin the speaker replacement by inserting the plastic opening tool into the corner of the device.
    • Work the plastic opening tool along the edge until you have separated the screen from the back plate.
  2. Insignia NS-15MS0832B Speaker  Replacement: passo 2, imagem 1 %32
    • Once the backplate is separated from the screen it should look like this.
  3. Insignia NS-15MS0832B Speaker  Replacement: passo 3, imagem 1 %32
    • Gently set the tablet screen-side down.
    • The speakers can be located at the bottom of the tablet, below the battery.
    • Using a screwdriver, remove the five 1.2 mm Phillips #1 screws that hold the speakers to the tablet.
  4. Insignia NS-15MS0832B Speaker  Replacement: passo 4, imagem 1 %32
    • Once first speaker has been removed, remove the other speaker opposite from it.
  5. Insignia NS-15MS0832B Speaker  Replacement: passo 5, imagem 1 %32
    • Once faulty speakers have been unscrewed, disconnect the speaker and attach the new speaker to the mother board.
Conclusão
Harrison Smith
Membro desde: 10/19/16
329 Reputação
Autoria de 3 guias
Equipe
Texas Tech, Team 1-1, Bennett Fall 2016 Membro de Texas Tech, Team 1-1, Bennett Fall 2016
TTU-BENNETT-F16S1G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 226
