Ir para o conteúdo principal
Insignia NS-15MS0832B Power Button Replacement
O que você precisa
  1. Insignia NS-15MS0832B Power Button Replacement, Power Button: passo 1, imagem 1 %32
    • The power button is located on the top side on the tablet, along side the charging port and MicroUSB port
  2. Insignia NS-15MS0832B Power Button Replacement: passo 2, imagem 1 %32
    • Starting in the corner, carefully insert the plastic opening tool.
    • Work the plastic opening tool carefully around the entire device to pry it open.
  3. Insignia NS-15MS0832B Power Button Replacement: passo 3, imagem 1 %32
    • Once the tablet is completely open, set aside the back half.
    • Carefully place the other half of the tablet screen-side down.
  4. Insignia NS-15MS0832B Power Button Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, gently grab the power button and pull it out from the tablet.
  5. Insignia NS-15MS0832B Power Button Replacement: passo 5, imagem 1 %32
    • Once the faulty power button is removed, follow the directions in reverse order to reassemble the device.
Conclusão
Harrison Smith
Membro desde: 10/19/16
329 Reputação
Autoria de 3 guias
Equipe
Texas Tech, Team 1-1, Bennett Fall 2016 Membro de Texas Tech, Team 1-1, Bennett Fall 2016
TTU-BENNETT-F16S1G1
4 Membros
Autoria de 6 guias
2Comentários do guia
If the power button doesn’t physically click anymore, can you order a replacement? Is it even possible to solder on a new power button?
Thanks in advance…
Chris - Responder
Can you do this with the volume rocker? My Insignia tablet has a faulty rocker, and I need to fix it. (Note- the “+” part of the volume button sticks and jams the volume to 100 until I press “-”.)
Andy Joonseo Bae - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 1,162
