Ir para o conteúdo principal
Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement
O que você precisa
  1. Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement, Water Tray: passo 1, imagem 1 %32 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement, Water Tray: passo 1, imagem 2 %32 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement, Water Tray: passo 1, imagem 3 %32
    • Remove the 6 screws holding the rear casing on.
    • Remove the rear casing
  2. Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: passo 2, imagem 1 %32 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: passo 2, imagem 2 %32 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: passo 2, imagem 3 %32
    • Remove the 4 screws holding the Ice Tray to the body of the Ice Maker.
  3. Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: passo 3, imagem 1 %32 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: passo 3, imagem 2 %32 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: passo 3, imagem 3 %32
    • Remove the 4 screws holding the Ice Tray from the top.
  4. Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: passo 4, imagem 1 %32 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: passo 4, imagem 2 %32
    • Lift the Water Pump out of the way
  5. Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: passo 5, imagem 1 %32 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: passo 5, imagem 2 %32 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: passo 5, imagem 3 %32
    • Remove the final 2 screws.
  6. Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: passo 6, imagem 1 %32 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: passo 6, imagem 2 %32 Insignia Ice Maker NS-IMP26SS7 Ice Tray Replacement: passo 6, imagem 3 %32
    • Remove the plastic cover from the circuit board by pressing the lever on the side. A pry tool may be required.
    • Disconnect the water tray cord.
Conclusão
Evan Taylor
Membro desde: 01/18/18
616 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S21-G3, Banghart Winter 2018 Membro de Cal Poly, Team S21-G3, Banghart Winter 2018
CPSU-BANGHART-W18S21G3
Membros da 2
Autoria de 5 guias
3 comentários
Where do I find insignia ice maker ns- imp26ss7 replacement ice forming tray? Can't locate item on the internet.
razorbllade - Responder
I found a seller on ebay that has 7 of them and is selling them for $20 shipped
er.vanlaarhoven -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 64
Duração total: 2,973
