Ir para o conteúdo principal
Insignia Flex 8 NS-P16AT08 Back Casing Replacement
O que você precisa
  1. Insignia Flex 8 NS-P16AT08 Back Casing Replacement, Back Casing: passo 1, imagem 1 %32 Insignia Flex 8 NS-P16AT08 Back Casing Replacement, Back Casing: passo 1, imagem 2 %32 Insignia Flex 8 NS-P16AT08 Back Casing Replacement, Back Casing: passo 1, imagem 3 %32
    • Make sure device is powered off.
    • Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
    • Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
    • You will hear the popping sound of the plastic connections separating from the device.
  2. Insignia Flex 8 NS-P16AT08 Back Casing Replacement: passo 2, imagem 1 %32
    • Lift the back casing away from the screen.
    • Set casing aside.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 600
