Ir para o conteúdo principal
Insignia Flex 8 NS-P08A7100 Battery Replacement
O que você precisa
  1. Insignia Flex 8 NS-P08A7100 Battery Replacement, Battery: passo 1, imagem 1 %32 Insignia Flex 8 NS-P08A7100 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Begin by using the opening tool to pry open the back cover. Continue around the edge until the back cover pops off.
  2. Insignia Flex 8 NS-P08A7100 Battery Replacement: passo 2, imagem 1 %32 Insignia Flex 8 NS-P08A7100 Battery Replacement: passo 2, imagem 2 %32
    • Use the opening tool to flip the LCD flex circuit plug upwards. The flex circuit should now be loose. Remove flex circuit by pulling outwards.
  3. Insignia Flex 8 NS-P08A7100 Battery Replacement: passo 3, imagem 1 %32 Insignia Flex 8 NS-P08A7100 Battery Replacement: passo 3, imagem 2 %32
    • Use the opening tool to remove the battery cable from the circuit board.
  4. Insignia Flex 8 NS-P08A7100 Battery Replacement: passo 4, imagem 1 %32
    • Remove the adhesive tape from the bottom of the battery.
  5. Insignia Flex 8 NS-P08A7100 Battery Replacement: passo 5, imagem 1 %32
    • Remove plastic adhesive tape from the side of the battery.
  6. Insignia Flex 8 NS-P08A7100 Battery Replacement: passo 6, imagem 1 %32 Insignia Flex 8 NS-P08A7100 Battery Replacement: passo 6, imagem 2 %32
    • Pry the battery from the back of the LCD screen using the opening tool. Due to the strong adhesive between the battery and screen, this may take some time.
Conclusão
Lavina Pillai
Membro desde: 07/08/19
133 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G1, Renguette Summer 2019 Membro de IUPUI, Team S1-G1, Renguette Summer 2019
IUPUI-RENGUETTE-SU19S1G1
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 235
