Ir para o conteúdo principal
Insignia Flex 8 NS-15AT08 Battery Replacement
O que você precisa
  1. Insignia Flex 8 NS-15AT08 Battery Replacement, Back Casing: passo 1, imagem 1 %32 Insignia Flex 8 NS-15AT08 Battery Replacement, Back Casing: passo 1, imagem 2 %32
    • Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet.
    • You may need to use a metal opening tool for extra prying power, but beware that it can scratch your device or damage the internal components if the tool is inserted too deep.
    • You will hear the tabs pop as you separate the back casing around the tablet.
    Pergunte ao FixBot
    Comentar
  2. Insignia Flex 8 NS-15AT08 Battery Replacement: passo 2, imagem 1 %32 Insignia Flex 8 NS-15AT08 Battery Replacement: passo 2, imagem 2 %32
    • Lift the back casing away from the rest of the device which should include the exposed circuit board and screen.
    • Set the casing aside.
    Pergunte ao FixBot
    Comentar
  3. Insignia Flex 8 NS-15AT08 Battery Replacement, Battery: passo 3, imagem 1 %32 Insignia Flex 8 NS-15AT08 Battery Replacement, Battery: passo 3, imagem 2 %32
    • Wedge a plastic opening tool in between the male, black module and female, white module to disconnect the wires module from the circuit board.
    Pergunte ao FixBot
    Comentar
  4. Insignia Flex 8 NS-15AT08 Battery Replacement: passo 4, imagem 1 %32 Insignia Flex 8 NS-15AT08 Battery Replacement: passo 4, imagem 2 %32 Insignia Flex 8 NS-15AT08 Battery Replacement: passo 4, imagem 3 %32
    • Use a plastic opening tool to pry the battery from the circuit board by wedging it around the perimeter of the battery.
    Pergunte ao FixBot
    Comentar
  5. Insignia Flex 8 NS-15AT08 Battery Replacement: passo 5, imagem 1 %32
    • Remove the battery from the circuit board by lifting it with the spudger or finger.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Jeremy Anaya
Membro desde: 09/23/15
316 Reputação
Autoria de 2 guias
Equipe
Baylor, Team 6-7, Williams Fall 2015 Membro de Baylor, Team 6-7, Williams Fall 2015
BU-WILLIAMS-F15S6G7
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 29
Ao todo: 2,124
