Ir para o conteúdo principal
Insignia Flex 8 NS-15AT08 Back Casing Replacement
O que você precisa
  1. Insignia Flex 8 NS-15AT08 Back Casing Replacement, Back Casing: passo 1, imagem 1 %32 Insignia Flex 8 NS-15AT08 Back Casing Replacement, Back Casing: passo 1, imagem 2 %32
    • Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet.
    • You may need to use a metal opening tool for extra prying power, but beware that it can scratch your device or damage the internal components if the tool is inserted too deep.
    • You will hear the tabs pop as you separate the back casing around the tablet.
  2. Insignia Flex 8 NS-15AT08 Back Casing Replacement: passo 2, imagem 1 %32 Insignia Flex 8 NS-15AT08 Back Casing Replacement: passo 2, imagem 2 %32
    • Lift the back casing away from the rest of the device which should include the exposed circuit board and screen.
    • Set the casing aside.
Conclusão
Krystal Rhodes
Membro desde: 09/22/15
488 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 6-7, Williams Fall 2015 Membro de Baylor, Team 6-7, Williams Fall 2015
BU-WILLIAMS-F15S6G7
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 32
Ao todo: 629
