Introdução
Broken screen is time to replace. For this replacement you will need to work from the back to the front of the tablet, the replacement of the screen will require the removal of the motherboard, since the screen is attached to the motherboard.
O que você precisa
Insert the edge of the plastic opener into the grove between the screen and back cover around the perimeter of the device.
Then using a gentle prying motion, create a gap large enough to use your fingers to separate the two halves.
Locate the three ribbon cables connecting components to the motherboard. The connections are covered with orange shielding tape. Peel the tape off the connectors and reserve for reassembly.
Each Zero Insertion Force or ZIF connector has a latch which holds the ribbon cable in place. The camera cable (a) and the LCD display cable (b) have a latch that lifts as shown in the illustration. Use a spudger to gently lift the latch to release the cable.
The touchscreen cable (c) has a sliding latch on each side of the connector. Use a spudger to carefully slide the latch on each side as shown to release the cable.
