Ir para o conteúdo principal
Insignia Flex 11.6 Screen Replacement
O que você precisa
  1. Insignia Flex 11.6 Screen Replacement, Power Removal: passo 1, imagem 1 %32 Insignia Flex 11.6 Screen Replacement, Power Removal: passo 1, imagem 2 %32 Insignia Flex 11.6 Screen Replacement, Power Removal: passo 1, imagem 3 %32
    • Before working on the device, make sure the device is off and not plugged into any power source for safety reasons. Failure to comply could result in injury.
    • Place the device on a firm surface with the device screen facing down.
  2. Insignia Flex 11.6 Screen Replacement: passo 2, imagem 1 %32 Insignia Flex 11.6 Screen Replacement: passo 2, imagem 2 %32
    • Remove 2, 6.1 mm Phillips J000 screws from the back of the device.
    • If any screws are stripped, refer to the ifixit guide for how to remove a stripped screw. How to Remove a Stripped Screw
  3. Insignia Flex 11.6 Screen Replacement: passo 3, imagem 1 %32 Insignia Flex 11.6 Screen Replacement: passo 3, imagem 2 %32 Insignia Flex 11.6 Screen Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Using a plastic tool and the plastic card, gently pry off the back cover.
  4. Insignia Flex 11.6 Screen Replacement: passo 4, imagem 1 %32 Insignia Flex 11.6 Screen Replacement: passo 4, imagem 2 %32 Insignia Flex 11.6 Screen Replacement: passo 4, imagem 3 %32
    Comprar
    • Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery.
  5. Insignia Flex 11.6 Screen Replacement, Motherboard: passo 5, imagem 1 %32
    • Unplug the 2 speaker's connection from the motherboard.
  6. Insignia Flex 11.6 Screen Replacement: passo 6, imagem 1 %32 Insignia Flex 11.6 Screen Replacement: passo 6, imagem 2 %32
    • Peel the yellow tape off from on top of the electrical connectors.
  7. Insignia Flex 11.6 Screen Replacement: passo 7, imagem 1 %32 Insignia Flex 11.6 Screen Replacement: passo 7, imagem 2 %32
    Comprar
    • Flip up the black cover pieces to expose the 3 electrical connectors.
    • Remove 3 electrical connectors by gently pulling back on them with some tweezers.
  8. Insignia Flex 11.6 Screen Replacement: passo 8, imagem 1 %32 Insignia Flex 11.6 Screen Replacement: passo 8, imagem 2 %32 Insignia Flex 11.6 Screen Replacement: passo 8, imagem 3 %32
    • Unplug the 2 black ground wires from the motherboard by gently prying on them until they unhook from the motherboard.
    • Remove the black camera connector by gently prying on it until it unhooks.
  9. Insignia Flex 11.6 Screen Replacement: passo 9, imagem 1 %32 Insignia Flex 11.6 Screen Replacement: passo 9, imagem 2 %32
    • Using tweezers, remove the microphone from the the plastic cover.
  10. Insignia Flex 11.6 Screen Replacement: passo 10, imagem 1 %32
    • Remove 5 - 3.4 mm Phillips J000 screws from the motherboard.
    • Motherboard pops out.
  11. Insignia Flex 11.6 Screen Replacement, Screen: passo 11, imagem 1 %32 Insignia Flex 11.6 Screen Replacement, Screen: passo 11, imagem 2 %32 Insignia Flex 11.6 Screen Replacement, Screen: passo 11, imagem 3 %32
    • Remove battery by prying off with card.
  12. Insignia Flex 11.6 Screen Replacement: passo 12, imagem 1 %32 Insignia Flex 11.6 Screen Replacement: passo 12, imagem 2 %32
    • Peel back the copper color electrical connector with blue opening tool.
  13. Insignia Flex 11.6 Screen Replacement: passo 13, imagem 1 %32
    • Remove 12 - 4.15mm J000 Phillips screws from the metal bracket.
    • Bracket will then come off.
  14. Insignia Flex 11.6 Screen Replacement: passo 14, imagem 1 %32
    • Remove 1 - 3.4 mm J000 Phillips screw from metal plate bracket.
  15. Insignia Flex 11.6 Screen Replacement: passo 15, imagem 1 %32 Insignia Flex 11.6 Screen Replacement: passo 15, imagem 2 %32
    • Remove screen from case by prying with a card.
Conclusão
4 outras pessoas executaram este guia.
6 comentários
The Flex 11.6" Model# NS-P11W7100 DOEST HAVE THOSE SCREWS RIGHT THERE!!!!!
Charles Kinnison - Responder
yeah, thats the one I have. its quite a bit different. the speaker wires are soldered, too…
Joshua Francis -
mine doesn’t look like that…
Joshua Francis - Responder
where can i get a new screen to buy?
florence sefaa - Responder
Do you sell the insignia ns-p11w7100 tablet 11.6 inches screen? I need on to fix my broken part.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 27
Duração total: 4,471
